I am using below 2 metrics for CPU usage for a vm and usage of cpu by elastic search process.
But I see the elastic search process CPU utilisation is more than overall CPU usage of the VM.
telegraf/plugins/inputs/cpu at master · influxdata/telegraf · GitHub
usage_user shows me the total cpu usage for a vm. -
telegraf/plugins/inputs/elasticsearch at master · influxdata/telegraf · GitHub
elasticsearch_process cpu_percent
Could you please tell me if I am using the right params.
Ideally elastic search process cpu should be lower than the total cpu utilization of the vm .
Please let me know if there is any other tag which i need to use to get the correct es process cpu utilisation metrics.
