How to add years to timestamp based on calculation result
I would like to add a number of years on timestamp based on calculation.
Without calculation (fix number), I know how to do, using date.add and formula for below exemple add 1 year to ‘_time’
 |> map(
        fn: (r) => ({ r with
           Year : date.year(t:r._time),
           NB_Year : date.year(t: now()) - date.year(t:r._time),
           New_Date : date.add(d: 1y, to: r._time),
Now I would like to add years based on the result calculation of NB_Year.
What is the syntax I will have to use ?
I’m sure it is basic but I do not know the syntax to use.
Thanks in advance for your help.
You are on the right path: date.year will return an integer; you need to convert it to a string then in to a duration type.
using string(v: value), then concatenate y using + “y”, then convert that string to a duration type using duration(d: value)
New_Date : date.add(d: duration(v: string(v: date.year(t: now()) - date.year(t:r._time) ) + "y"), to: r._time),,
Thank you @fercasjr , I did not see these steps.
It works perfectly and fit exctly what I need.
Thanks a lot again :wink:
