home automation
I want to ask for help.
I have a self-installed smart house (Inels system).
Displays the values ​​of the sensors connected to it on one port (192.168.1.1:1111) of the central computer line by line.
I would like to save these values ​​to a file with a timestamp.
Which program would be suitable for the described task?
Thanks if you can help.
Sincerely,
Chisee
Care, waiting for help
Hello @stellaa9x @Chisee,
Welcome!
You’ll probably need to write a little code to scrape the data and convert into line protocol. But then you can use telegraf to write the data to InfluxDB . What does the data look like at that endpoint?
