Hard disk Sizing
#1
I have a use case,where i need to store time series for long period (10 years) with data around 100 TBs
I plan to use InfluxDB Enterprise with clustering.
  1. How to many nodes do i need ?
  2. Is there any recommendation on max hard disk per node ?
Regards,
Pradeep
#2
There are some very general recommendations for disk size, but they depend more on the load than any number of nodes. If you’re planning on using Enterprise, a sales engineer will be able to tell you much better how many nodes suit your needs.
