Gnmi metric filters behaviour
I have the following gnmi config (one per node):
[[inputs.gnmi]]
addresses = [“testnode:6030”]
username = “$USERID”
password = “$PASSWORD”
[[inputs.gnmi.subscription]]
name = “smashcounters”
origin = “eos_native”
path = “/Smash/counters/strataDebugCounter/StrataCounters/current/intfDebugCounter”
subscription_mode = “sample”
sample_interval = “60s”
name = “lanz”
path = “/LANZ”
The “smashcounters” subscription returns a massive amount of fields, but I am only interested in a tiny subset. I can use:
fieldpass = [“*platformCounters/rxVlanDrop”]
to filter by field, but what I found is this only works at the toplevel inputs.gnmi. The config allows metric filters to be specified in the [[inputs.gnmi.subscription]] sections but they are ignored. Looking at the code and testcases I do not see tests for this use case.
I know I can repeat [[inputs.gnmi]] sections, but this has undesirable side effects - each [[inputs.gnmi]]
opens a new connection to the node. Subscriptions are thus not shared over a single connection.
I would really like to filter as much as possible at the input stage. Currently I am letting all the fields pass to the output stage and then only allowing what I want into Kafka.
Fieldpass and the other metric filters work at the input level. They have no knowledge of the various subscriptions you are making.
You could use a starlark processor to write some logic to remove any fields you want depending on the subscription.
