Failed to validate Oauth settings: missing Google oauth setting[s] error after upgrade to 1.8.4
I upgraded my influxdb server today, like I did countless times before. After the upgrade, chronograf would not start. It logs the following error:
level=error msg=“Failed to validate Oauth settings: missing Google oauth setting[s]: client id, client secret” basepath=invalid component=server
I’m not even using Google OAuth, I have Generic OAuth configured in /etc/default/chronograf. All the settings are there as per the AzureAD generic OAuth configuration example.
I would really appreciate any pointers.
@buzzlightyear thanks for the comment. We believe this issue was fixed in fix: remove common public-url config from oauth validation check (#5475) · influxdata/chronograf@00cce51 · GitHub but has not been released yet. It is in master and the nightly available on Downloads. We are planning an updated release in the next few weeks.
Thanks @russ_savage I downgraded chronograf to 1.7.17 and back up and running.
This topic was automatically closed 60 minutes after the last reply. New replies are no longer allowed.
