I’m getting a Failed to download shard backup: An internal error has occurred
when trying to run a backup. See the entire printout below.
I’m using the 2.0 OSS docker image (2.0.9) hosted in Azure Container Instances. One thing that might be relevant here is that I have an Azure File Share mounted to my container, and that I have both the Bolt path and engine path pointed to this file share (using --bolt-path=/aci/db/influxd.bolt
and --engine-path=/aci/db/engine
). Also note that I’m not using the standard port 8086, but rather 9999.
My backup command is /usr/local/bin/influx backup /aci/db/backup --host http://<name>.northeurope.azurecontainer.io:9999 --token <token>
And here’s the printout:
2021-10-15T05:05:36.220021Z info Backing up KV store {"log_id": "0XCaJ1pl000", "path": "/aci/db/backup/20211015T050536Z.bolt"}
2021-10-15T05:05:36.362044Z info Resources opened {"log_id": "0XCaJ1pl000", "path": "/aci/db/backup/20211015T050536Z.bolt"}
2021-10-15T05:05:36.373678Z info Backing up organization {"log_id": "0XCaJ1pl000", "id": "cde2791a53d987d4", "name": "XXXXXX"}
2021-10-15T05:05:36.378281Z info Backing up bucket {"log_id": "0XCaJ1pl000", "id": "50df484acf706ca0", "name": "_monitoring"}
2021-10-15T05:05:36.378399Z info Backing up bucket {"log_id": "0XCaJ1pl000", "id": "9f983ea8987ecaf6", "name": "_tasks"}
2021-10-15T05:05:36.378551Z info Backing up bucket {"log_id": "0XCaJ1pl000", "id": "54885bd02d196ccf", "name": "(some bucket)"}
2021-10-15T05:05:36.378590Z info Backing up bucket {"log_id": "0XCaJ1pl000", "id": "ad8b1a11184c7561", "name": "(another bucket)"}
2021-10-15T05:05:36.378662Z info Backing up shard {"log_id": "0XCaJ1pl000", "id": 332, "path": "/aci/db/backup/20211015T050536Z.s332.tar.gz"}
Error: Failed to download shard backup: An internal error has occurred.
See 'influx backup -h' for help
Thank you!
