I have a log file that i want to parse and send the data to my influx database.So here is the thing that i want to do
Consider the two types of log that i want to parse:
First :
Jun 30 00:46:36 raspberrypi mender[869]: level=error msg=“failed to send deployment logs to server: transient error: failed to send deployment logs: transient error: (request_id: ): uploading logs failed, bad status 413 server error message: failed to parse server response: invalid character ‘<’ looking for beginning of value”
Second :
Jun 30 12:07:23 raspberrypi rngd[396]: stats: FIPS 140-2(2001-10-10) Runs: 0
now i want to have the following data in my InfluxDB:
for first log:
column Name - column value
time - 1593672519370595355
severity - error(extracted from the first log)
value - Jun 30 00:46:36 raspberrypi mender[869]: level=error msg=“failed to send deployment logs to server: transient error: failed to send deployment logs: transient error: (request_id: ): uploading logs failed, bad status 413 server error message: failed to parse server response: invalid character ‘<’ looking for beginning of value” (complete first log)
for second log:
time - 1593672519370614724
severity - (empty since there is no error indication in the log)
value - Jun 30 12:07:23 raspberrypi rngd[396]: stats: FIPS 140-2(2001-10-10) Runs: 0 (complete second log)
what config of input.tail should i use to achieve this output?
