I am currently trying to setup an external connection to influx 1.8 to use with Grafana.
This is the desired domain access point
"Influx Database Url": http://influx.domain:8086
I am trying to get http to work before setting it up securely with https
The only thing is I can’t figure out how to set influx to that path.
I tried influx -path influx.domain
but it doesn’t seem to set it because it goes into the terminal and says
Connected to http://localhost:8086 version 1.8.10
InfluxDB shell version: 1.8.10
and my external plugin isn’t connecting to the database url
TDLR: Needing to set the database url but it isn’t working
