Hi all,
I want to translate the following Chinese documents of influxdb v1.8, but after pulling the code on githup, I found an error when starting the local server according to the instructions.
$ hugo server
Start building sites …
ERROR 2020/12/01 10:40:20 TOCSS: failed to transform “styles/styles-dark.scss” (text/x-scss): resource “scss/styles/styles-dark.scss_f4320040a399b68ce06274b21a585702” not found in file cache
ERROR 2020/12/01 10:40:20 TOCSS: failed to transform “styles/sidebar-open.scss” (text/x-scss): resource “scss/styles/sidebar-open.scss_f4320040a399b68ce06274b21a585702” not found in file cache
ERROR 2020/12/01 10:40:20 TOCSS: failed to transform “styles/sidebar-closed.scss” (text/x-scss): resource “scss/styles/sidebar-closed.scss_c9dc9c81542e3a5ddc9fcb14853c6bc7” not found in file cache
ERROR 2020/12/01 10:40:20 TOCSS: failed to transform “styles/styles-api.scss” (text/x-scss): resource “scss/styles/styles-api.scss_8ec1c3f1ece3ef0ee38d1e370b96f6a8” not found in file cache
Built in 91674 ms
Error: Error building site: TOCSS: failed to transform “styles/styles-default.scss” (text/x-scss): resource “scss/styles/styles-default.scss_c9dc9c81542e3a5ddc9fcb14853c6bc7” not found in file cache
How can I get these missing files?
