Hi Team
I want to export the list of images deployed in the AWS EKS cluster, for which am planning to use kube_invetory plugin and kubernetes plugin but both of these plugins dont export the image parameter, so am trying to use docker plugin which will export image plugin, so i want to know if docker plugin can be configured to cloud deployed (AWS EKS) Kubernetes, if yes could you please share some info on how to configure this AWS EKS kubernetes.
I’m not sure if there is any way to export the data you want. The best way forward would be to add a feature request. Ideally you can also implement the feature and create a pull-request.
