Hi
I am a bit confused, I have set my default retention policy to 48 hours with shard duration 2 hours.
I updated the RP before starting to write data.
I would expect no data older than Nov 28 (2 days ago).
However I have data much older than that, do i need to do something else to make the retention policy active?
>show retention policies
name duration shardGroupDuration replicaN default
autogen 48h0m0s 2h0m0s 1 true
> select * from gridFrequency order by time limit 10
time container device factor id int_value units
2020-11-25T13:05:00Z 1 fmeter 10000 1 499950 Hz
2020-11-25T13:05:06Z 1 fmeter 10000 1 499825 Hz
2020-11-25T13:05:11Z 1 fmeter 10000 1 499742 Hz
2020-11-25T13:05:16Z 1 fmeter 10000 1 499652 Hz
2020-11-25T13:05:21Z 1 fmeter 10000 1 499695 Hz
2020-11-25T13:05:27Z 1 fmeter 10000 1 499852 Hz
2020-11-25T13:05:32Z 1 fmeter 10000 1 499933 Hz
2020-11-25T13:05:38Z 1 fmeter 10000 1 500024 Hz
2020-11-25T13:05:43Z 1 fmeter 10000 1 500024 Hz
2020-11-25T13:05:48Z 1 fmeter 10000 1 500116 Hz
Any suggestions much appreciated.
