Tags are not loading at all for “CPU” measurement in chronograf UI… for other measurements its loading properly.
Upon investigating , found that Chronograf posts following metadata query to InfluxDb when we select CPU metric in chronograf UI and it goes to pending state as there is no response back from InfluxDB for longer duration and then times out
SHOW TAG VALUES FROM "autogen"."cpu" WITH KEY IN ("GlobalMon.Site", "__auth_key", "_resourcegroup_", "_subscription_", "_team_", "application", "cluster_owner", "cpu", "cynosure.isCynosure", "dc", "dspa.xdm application", "dspa.xdm environment", "env", "host", "hostname", "logfile", "month", "namespace", "weekday", "year")"
This metadata query works fine when posted without Tag key “CPU”.
SHOW TAG VALUES FROM "autogen"."cpu" WITH KEY IN ("GlobalMon.Site", "__auth_key", "_resourcegroup_", "_subscription_", "_team_", "application", "cluster_owner", "cynosure.isCynosure", "dc", "dspa.xdm application", "dspa.xdm environment", "env", "host", "hostname", "logfile", "month", "namespace", "weekday", "year")"
TAG value cardinality for key "CPU "- in CPU measurement is 418
Tried posting following query manually in Influx data node command line and it takes longer duration and never loads.
SHOW TAG VALUES ON "vc" FROM "autogen"."cpu" WITH KEY IN ("cpu")
Any pointers how to troubleshoot this ?
influx version is 1.8.2 ,
chronograf version is 1.8.0
