I seem to be failing to chain topics. Am I overlooking something? Kapacitor v1.3
What I would like, is for any alert in my example_critical_absolute
to be arrive in topic sysops
, via another topic testing_errors with a public action. However, collected stays as 0:
!rik@pc411 ~ $ kapacitor show example_critical
Error:
Template:
Type: stream
Status: enabled
Executing: true
Created: 16 Jan 18 12:46 UTC
Modified: 17 Jan 18 12:59 UTC
LastEnabled: 17 Jan 18 12:59 UTC
Databases Retention Policies: ["test"."def"]
TICKscript:
var limit = 0.2
var data = stream
|from()
.measurement('testing')
|window()
.period(5m)
.every(1m)
|mean('value')
.as('mean')
data
|influxDBOut()
.database('test')
.retentionPolicy('def')
.measurement('example_critical_mean')
data
|alert()
.id('example_critical_absolute')
.crit(lambda: "mean" > limit)
.topic('testing_errors')
DOT:
digraph example_critical {
graph [throughput="1.00 points/s"];
stream0 [avg_exec_time_ns="0s" errors="0" working_cardinality="0" ];
stream0 -> from1 [processed="4478"];
from1 [avg_exec_time_ns="0s" errors="0" working_cardinality="0" ];
from1 -> window2 [processed="4478"];
window2 [avg_exec_time_ns="0s" errors="0" working_cardinality="1" ];
window2 -> mean3 [processed="82"];
mean3 [avg_exec_time_ns="0s" errors="0" working_cardinality="0" ];
mean3 -> alert5 [processed="82"];
mean3 -> influxdb_out4 [processed="82"];
alert5 [alerts_triggered="20" avg_exec_time_ns="0s" crits_triggered="18" errors="0" infos_triggered="0" oks_triggered="2" warns_triggered="0" working_cardinality="1" ];
influxdb_out4 [avg_exec_time_ns="0s" errors="0" points_written="82" working_cardinality="0" write_errors="0" ];
!rik@pc411 ~ $ kapacitor show-topic testing_errors
Level: CRITICAL
Collected: 42
Handlers: [testing_errors_chain]
Events:
Event Level Message Date
example_critical_absolute CRITICAL example_critical_absolute is CRITICAL 17 Jan 18 15:26 CET
!rik@pc411 ~ $ kapacitor list topic-handlers
Topic ID Kind
testing_errors testing_errors_chain publish
!rik@pc411 ~ $ kapacitor show-topic-handler testing_errors testing_errors_chain
Topic: testing_errors
Kind: publish
Match:
Options: {"topics":["noc","be","sysop"]}
!rik@pc411 ~ $ kapacitor show-topic sysops
Level: OK
Collected: 0
Handlers: []
Events:
