Calculated field and additional column with currency
is there an easier and more performant solution to add the currency column here?
t1=
  from(bucket: "VH_Messwerte")
  |> range(start: ${ErsterTagJahr}, stop: now())
  |> filter(fn: (r) => r["topic"] == "Heizen/WP/GesElEnergie")
  |> filter(fn: (r) => r["_field"] == "value")
  |> difference()
  |> map(fn: (r) => ({r with _value: (float(v: r._value) / 1000.0 )} ))
  |> aggregateWindow(every: 1y, fn: sum, createEmpty: false)
t2=
  |> difference()
  |> map(fn: (r) => ({r with _value: ((float(v: r._value) / 1000.0) *${EUR_kWh_WP} )} ))
  join(tables: {t1: t1, t2: t2}, on: ["_time"])
Thanks You
Hi @matze1708,
If you are using InfluxDB Cloud / InfluxDB OSS 2.5 you can optimize slightly like this:
rawdata = () => from(bucket: "VH_Messwerte")
  |> difference()
t1=
rawdata()
t2=
rawdata()
  |> map(fn: (r) => ({r with _value: ((float(v: r._value) / 1000.0) * ${EUR_kWh_WP} )} ))
This saves retrieval twice. If you can also find a way of swapping your map and aggregate windows round i.e.
//to
This would also help as aggregate window is a pushdown function
Thank you! This is exactly what I’m looking for!
Is there also a way to rename the fields at the end?
for example Value and Currency
Hi @matze1708,
Not a problem! You could use set() function | Flux 0.x Documentation
