Hello!
I´m new in influx and used before emoncms.
I use java and always upload 10 measurements at once.
Is this also with influx possible? The source code what it shows, is only for one measurement per upload.
Thank you!
Hello!
Thank you!
hello @hanhoe,
What version of InfluxDB are you using?
And what is your data coming from? What does your input data currently look like? There might be other solutions for ingesting data.
I recommend checking out Telegraf if you haven’t already.
You can also upload CSV with the UI and CLI in certain versions.
