I’m facing some issues with my InfluxDB, which is allocating all the available RAM on the server.
I’m running InfluxDB v1.8.3 on Windows, it worked (almost) fine until now.
The only “error” I have in the log is this one
block read error on __PointKey__ StringArrayEncodeAll: source length too large
That measurement contains the SQL statement executed in SQL Server, which is saved as a field string. (and can be huge)
Here is the InfluxDB log
ts=2020-10-06T11:00:25.142416Z lvl=warn msg="Error compacting TSM files" log_id=0PgJeCr0000 engine=tsm1 tsm1_strategy=full tsm1_optimize=false trace_id=0PgNLqZl000 op_name=tsm1_compact_group error="block read error on I:\\Monitoring\\influxdb\\SqlServerGT\\data\\monitor\\standard\\387\\000001039-000000002.tsm: encode error: unable to compress block type string for key 'sqlserver_requests,command=EXECUTE,host=SRV-MGMAPPPRD03,host_name=SRV-DLOAPPPRD02,nt_user_name=Svc_APDLOCOL-P,program_name=.Net\\ SqlClient\\ Data\\ Provider,session_db_name=MyDatabase,sql_instance=SRV-DLOSQLPRD01,status=running,stmt_db_name=MyDatabase,transaction_isolation_level=2-Read\\ Committed#!~#statement_text': StringArrayEncodeAll: source length too large, block read error on I:\\Monitoring\\influxdb\\SqlServerGT\\data\\monitor\\standard\\387\\000001039-000000002.tsm: encode error: unable to compress block type string for key 'sqlserver_requests,command=EXECUTE,host=SRV-MGMAPPPRD03,host_name=SRV-DLOAPPPRD02,nt_user_name=Svc_APDLOCOL-P,program_name=.Net\\ SqlClient\\ Data\\ Provider,session_db_name=MyDatabase,sql_instance=SRV-DLOSQLPRD01,status=running,stmt_db_name=MyDatabase,transaction_isolation_level=2-Read\\ Committed#!~#statement_text': StringArrayEncodeAll: source length too large"
ts=2020-10-06T11:00:30.138592Z lvl=info msg="TSM compaction (end)" log_id=0PgJeCr0000 engine=tsm1 tsm1_strategy=full tsm1_optimize=false trace_id=0PgNLqZl000 op_name=tsm1_compact_group op_event=end op_elapsed=1691496.690ms
Can this “error” cause any issue? will the file be compacted or not?
