For a project we are trying to monitor a status protocol sent on local network over TCP and post these status messages over HTTPS to a InfluxDB instance on AWS at InfluxDB Cloud - The Most Powerful Time Series Database As a Service.
We are using a teensy 4.1 with a ethernet kit in combination with the Native Ethernet library by vjmuzik GitHub - vjmuzik/NativeEthernet: Native Ethernet library for Teensy 4.1.
Posting a string to a test instance over LAN to a IP works fine, but whenever we try to post to the AWS subdomain we are greeted with this response:
HTTP/1.1 400 Bad Request
Server: awselb/2.0
Date: Mon, 27 Sep 2021 18:13:02 GMT
Content-Type: text/html
Content-Length: 122
Connection: close
400 Bad Request
Since we verified the headers and body of the post are correct when we post locally, and posting to AWS works when using Postman, we are at a loss at the moment. Unfortunately I have no information about the configuration of the server we try to POST to.
As a test we set-up the WebClientRepeatingTLS example using our own POST headers and body.
#include <NativeEthernet.h>
uint8_t mac[6];
void teensyMAC(uint8_t *mac) {
for (uint8_t by = 0; by < 2; by++) mac[by] = (HW_OCOTP_MAC1 >> ((1 - by) * 8)) & 0xFF;
for (uint8_t by = 0; by < 4; by++) mac[by + 2] = (HW_OCOTP_MAC0 >> ((3 - by) * 8)) & 0xFF;
Serial.printf("MAC: %02x:%02x:%02x:%02x:%02x:%02x\n", mac[0], mac[1], mac[2], mac[3], mac[4], mac[5]);
// initialize the library instance:
EthernetClient client;
const int port = 443;
char server[] = "influxdata.com";
//IPAddress server(192, 168, 1, 246);
String outputMSG = "measurementName,tagKey=tagValue fieldKey=1i";
unsigned long lastConnectionTime = 0; // last time you connected to the server, in milliseconds
const unsigned long postingInterval = 5 * 1000; // delay between updates, in milliseconds
void setup() {
teensyMAC(mac);
Serial.begin(9600);
while (!Serial) {
Serial.println("Initialize Ethernet with DHCP:");
if (Ethernet.begin(mac) == 0) {
Serial.println("Failed to configure Ethernet using DHCP");
if (Ethernet.hardwareStatus() == EthernetNoHardware) {
Serial.println("Ethernet shield was not found. Sorry, can't run without hardware. :(");
while (true) {
delay(1);
if (Ethernet.linkStatus() == LinkOFF) {
Serial.println("Ethernet cable is not connected.");
} else {
Serial.print(" DHCP assigned IP ");
Serial.println(Ethernet.localIP());
delay(1000);
void loop() {
if (client.available()) {
char c = client.read();
Serial.write(c);
if (millis() - lastConnectionTime > postingInterval) {
httpRequest();
void httpRequest() {
client.stop();
Serial.print("Content-Length: ");
Serial.println(outputMSG.length());
Serial.println("");
if (client.connect(server, port, true)) {
Serial.println("connecting to ");
Serial.print(server);
Serial.print(":");
Serial.println(port);
client.println("POST /api/v2/write?org=ORG_HERE&bucket=BUCKET_HERE&precision=s HTTP/1.1");
client.println("Host: https://eu-central-1-1.aws.cloud2.influxdata.com");
client.println("Authorization: Token <<TOKEN HERE>>");
client.println("Content-Type: text/plain");
client.print("Content-Length: ");
client.println(outputMSG.length());
client.println("Accept-Encoding: gzip, deflate, br");
client.println("Connection: keep-alive");
client.println();
client.println(outputMSG);
client.println();
lastConnectionTime = millis();
} else {
Serial.println("connection failed");
Could anyone help us understand why the post to aws is not going through?
Cheers,
Boy
